How does setup time impose maximum delay and hold time the minimum delay?
ananth_anbu
hi,
i have doubt in setup and hold time. Setup time imposes a maximum delay requirement, Hold time imposes a minimum delay requirement. How? ple. explain me
Re: setup and hold
this is because this are not tpd delay values.
for tco you will have maximum tpd time which is important.
however thold is imposed on the logic driving the part. i.e it has to have min. thold
time, the max is infinity.
for setup it is also imposed on driving device, since it now have to support certein tmax tpd to support the ts restriction, a minimum 0 tpd will be excellent.
    ananth_anbu
Re: setup and hold
tco clock to output. (synchronous)
tpd propogation delay .(combinatoric).
Re: setup and hold
thanks for the reply......
but i need definition for the Tco and Tpd
Re: setup and hold
Plzz EDALIST and SHAWNDAKING...
* tco clock to output. is synchronous?? how??
explain me with an example
thanx in advance
setup and hold
This is because even the flipflop modeled is internally a combo logic and it requires some time delay for the input data to be latched to output
Re: setup and hold
What does it have to do with time for clock to output be synchronous?.FF's are synchronous...
Also Try this
Flip flops are synchronous nodes. On the active edge of the clock, the output of the flip flop changes to the state of the input and holds that state throughout the next clock cycle. Synchronous nodes are connected to the clock signal.
Simple gates like ANDs or ORs are asynchronous nodes. Their output changes - with a short delay - whenever one of their inputs changes. During that transition phase, the output can even go into some undefined or intermediate state
You might wanna take a look at this for some basic info
If it's helpful enough,feedback here
setup and hold
GuyZ
Tco is simply the time between the rising/falling clock edge triggering the clk input of the FF and the appearance of the data at the FF output ..
In other words, the Q output of the FF doesn't appear instantaneousely once the clock edge triggers the clock input of the FF .. it takes time till the output appears .. this time is known as Tco ..
