How does pressure will increase when we compress the air?
rameshbabu
Member level 2
Member level 2
when we compress the air , how the pressure will increase.
when pressure increases does the energy increases.
Re: pressure
rameshbabu,
In answer to the second part of your question, If the pressure increases due to external influences, the energy does increase.
Regards,
Kral
Re: pressure
If we try to compress air container, some work is done on the air or its container ..
So , this work done in compressing is used to raise the internal internalenergy of air molecules.
Hence , energy increases.
PV = constant , where P is pressure, V is Volume.
P is inversely proportinal to volume .i.e. due to compression as the volume decreases the pressure increses.
pressure
V is volume and it is a container. v is const.
So if ull increase pressure there will be more molecules in a container, due it energy will increase coz molecules are energy and als o they want room to play, so ull get higher pressure.
Pressure is force per area. not volume...
But thease 2 are very much related to eo.
