How does microcontroller work with flashing sequence order ?
maher_alp
Newbie level 5
Newbie level 5
tk3prog.exe
hi
i need to know how microcontroller work with flashing sequence order which i do control of it.
you may tell me hardware and software implementation.
for example traffic light control.
thanx
tk3prog
As far as I understand your post you would like to know how to use a microcontroller to turn someting on and off in a sequence.
To performe this task a microcontroller generates time intervals of say 1s and according to pre-programmed procedure sets outputs high or low. LOw output means the "light" is off, high output = "light" on.
If the microcontroller is connected to a radio link you can control its functions remotely i.e you can speed up the running sequence or just change it ..
Re: flashing microcontroller
what is the target microcontroller you want to use for your project?
Hi brother.........!
How are you !
I want to say that i found a new book for you about PIC microcontroller You can download it from this link:
May be it will be useful for you!
My greetings for you Maher!
Your brother :Mohammed Ali Zaiter
BEY
thanx all of you for you concern .
but i need to know about TK3pROG.EXE and how it work
and how to deial with
Hi Maher
I found about this microcontroller But iwant to say that Your Microcontroller is PIC microcontrooler and that was an EXE file only
and you can visit this web page to be shure!
My Greetings>>>>M.A.Z
Added after 8 minutes:
Iforgot to say that you can visit this site it talking about microcontrollers and it is in ARABIC
And i think it is useful!
thanx for you ali
if you can tell me about 80c196kb microcomputer and its interfacing with 80c196 clock speed of 12MHz
hardware only
Hello Maher !
I think this microcomputer had been made by INTEL company and I succeded to bring you an E-BOOK taking About USING 80c196kb microcomputer it has plans for every thing and you can download it from this site:
http://support.intel.com/design/mcs96/applnots/27211601.pdf
it is very small but so useful!
BEY
