jujuChenYi
Integrating "Volume_Loss _Density" and "Substrate" using field calculator can obtain the dielectric loss,the same way to calculate conductor loss, the answer is zero. why? How can I calculate conductor loss?
Hi, I want to view the conductor loss power and dielectric loss power in the HFSS simulation results. The dielectric loss power can be calculated in the HFSS calculator using the method I mentioned earlier , but the conductor loss calculated using the same method is 0o you mean how to measure resistance from conductor geometry and density with skin effects (f) for a given current?
