SanjKrish
Member level 3
Please correct if my understanding of how voltage current working is wrong..
An electricity generator which is fuelled at a constant rate provides constant voltage across its ends say 230V.. This generator rotates at say 100 rpm and can light a bulb with gud luminosity..
( This is compared to a boy pedaling a bicycle at a plane surface for his level of energy which he can pedal at 100 rpm)
When more number of such light bulbs are connected in parallel, certainly the luminosity of the light bulbs decrease cause of increased current demand which exerts an oposing force on the turbine decreasing its speed to say 50 rpm, ( Can I still say the generator generates 230V as it is fueled at a constant rate ??)
( This is compared to a boy encountering an uphill but still pedals at his same energy level(voltage level) decreasing his speed and his pedaling to 50 rpm (lower current))
Inorder to maintain the same current flow (which is done to maintain the bulbs glow at the same luminosity) the generator is fuelled at a higher rate and the generator goes back to it orginal speed of 100 rpm.. but this time as more fuel is provided does it mean tat the voltage level is increased??? inoder to provide constant current..
Now, I am not able to make my question itself.. Sorry.. Soo confused..:shock:
How does the power plants always give 230V to homes.. is it by running the turbine at constant speed??? and how is the current taken care if not by the speed of the turbine...
Please excuse me if my questing is dumb..
