SanjKrish
Member level 3
I noticed the graph of zener diode and the normal diode is almost the same..
Now, while a normal diode when operated below the breakdown voltage gets permanently damaged...
how does the zener diode survive even after being operated below the breakdown voltage??
All I know is tat zener is heavily doped.. and when a strong reverse bias is applied.. causes mobile holes in the P region and the mobile electrons in the N region to sucked by the battery terminals leaving behind a depletion region made of immobile negative and positive ions in the P and N regions respectively..
Having said till this, how does it make a difference in working of both the diodes below the breakdown voltage..
Also I'm confused with the difference between zener breakdown and avalanche breakdown..
I read zener breakdown is cause by rupture of covalent bond due to heavy revese bias so the electrons make themselves free of the covalent bond and start conducting..
and avalanche breakdown is caused by the minority careers hitting the covalent bonds at high speed which creates the avalanche(like a glacier falling)..
both seems to be one at the same.. caused by rupture of covanlent bonds and subsequently conduction..
