How does a DMM measure voltage, current, and resistance exactly?
teddybear211
Newbie level 5
Newbie level 5
I want to make a software program which emulates a DMM, but have no clue as to how the DMM actually measures these 3. I know Ohm's Law is used.
For measuring voltage I was wondering if the DMM probes have a huge input resistance? For current I was wondering if the DMM probes then change to a small input resistance. I have no clue as to how resistance is measured.. Maybe with a constant supply of current and voltage? I'm not too sure. Help please!
Basically, they actually measure only voltage. In order to measure current, they measure the voltage across an internal "current-sensing" resistor, which is usually a low value but would probably depend on the range selected. To measure resistance, I think they apply a small voltage across the probes and measure the resulting current by measuring the voltage across a small resistor (again, the value probably depends on the range selected). Then Ohm's law is used.
Someone else will probably come along with some more-precise information. or you can look up a circuit somewhere and see exactly how it's done.
