How does a digital phase lock loop function?
scdoro
Member level 5
Member level 5
hi everyone,
Qn(a): How does a digital phase lock loop function?
Qn(b): Can a digital phase lock loop be used be used to synchronize asynchronous data with the clock? If yes, how?
thanks
Phase lock loop
this is a sample IC which use DPLL :
and this one used to syncronized PCM data at reciver side.
I hope this is helpful.
Re: Phase lock loop
i am actually trying to tap the keyboard clock from the PS/2 KBD pin. and use it to synchronize with asynchronous data running at baud rate of 9600bits/sec.For each data frame transmitting, at each trailing edge of the clock,it will fall/sampled on the middle of each data bit..It will then be sent to the keyboard port.
P.S: the IC chip for the website you gave me seems to be obsolete.Are there any other schematics or IC chip that will suit my needs..
thanks a lot.
regards
Phase lock loop
That link was for finding DPLL principle.
I dont underestand you problem very well, but as i know asyncronus serial port dont need DPLL!
