How do you set grids in Altium library and schematic
T
treez
Newbie level 1
How do i set the grids (visiable and snap) to 0.1 inch in the library program....how do i change the units to inches.
How do i set the grids (visible and snap) to 0.1 inch in the library program
press G, then enter your desired grids.
press Q to toggle between imperial and metric
Reactions: treez
    T
Thanks, but in the library editor, i set all the grids, electrical, snap, and visible to 0.1 inch, and then the screen grid lines are 10 apart....i am not sure where the 10 comes from when i selected 100 thou (0.1 inch)
did you zoom in enough to actually see the grid spacing? If you are zoomed out, it can look different.
Reactions: treez
    T
