This program was produced by the
CodeWizardAVR V1.23.3 Standard
Automatic Program Generator
© Copyright 1998-2002 HP InfoTech s.r.l.
https://www.hpinfotech.ro
e-mail
ffice@hpinfotech.ro ,
hpinfotech@xmail.ro
Project : Stepper motor control using the ULN2003
Version : 1
Date : 5/30/2002
Author : Thomas Lui
Company : Thomtronics Technology Company
Comments:
Connection:
letATworkII ULN2003
PORTB.0 <---- PIN 1 PIN 16 ---->|------------------|
PORTB.1 <---- PIN 2 PIN 15 ---->| Stepping Motor |
PORTB.2 <---- PIN 3 PIN 14 ---->| |
PORTB.3 <---- PIN 4 PIN 13 ---->|------------------|
GND <---- PIN 8 | |-----------|
PIN 9 --|--> 9V-12V (Depend on Stepping Motor)
Chip type : ATmega128
Program type : Application
Clock frequency : 16.000000 MHz
Memory model : Small
Internal SRAM size : 4096
External SRAM size : 0
Data Stack size : 1024
#include <mega128.h>
#include <delay.h>
// Declare your global variables here
void main(void)
// Declare your local variables here
// Input/Output Ports initialization
// Port A initialization
// Func0=In Func1=In Func2=In Func3=In Func4=In Func5=In Func6=In Func7=In
// State0=T State1=T State2=T State3=T State4=T State5=T State6=T State7=T
PORTA=0x00;
DDRA=0x00;
// Port B initialization
// Func0=Out Func1=Out Func2=Out Func3=Out Func4=In Func5=In Func6=In Func7=In
// State0=0 State1=0 State2=0 State3=0 State4=T State5=T State6=T State7=T
PORTB=0x00;
DDRB=0x0F;
// Port C initialization
PORTC=0x00;
DDRC=0x00;
// Port D initialization
PORTD=0x00;
DDRD=0x00;
// Port E initialization
PORTE=0x00;
DDRE=0x00;
// Port F initialization
PORTF=0x00;
DDRF=0x00;
// Port G initialization
PORTG=0x00;
DDRG=0x00;
// Timer/Counter 0 initialization
// Clock source: System Clock
// Clock value: Timer 0 Stopped
// Mode: Normal top=FFh
// OC0 output: Disconnected
TCCR0=0x00;
ASSR=0x00;
TCNT0=0x00;
OCR0=0x00;
// Timer/Counter 1 initialization
// Clock value: Timer 1 Stopped
// Mode: Normal top=FFFFh
// OC1A output: Discon.
// OC1B output: Discon.
// OC1C output: Discon.
// Noise Canceler: Off
// Input Capture on Falling Edge
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
OCR1CH=0x00;
OCR1CL=0x00;
// Timer/Counter 2 initialization
// Clock value: Timer 2 Stopped
// OC2 output: Disconnected
TCCR2=0x00;
ASSR=0x00;
TCNT2=0x00;
OCR2=0x00;
// Timer/Counter 3 initialization
// Clock value: Timer 3 Stopped
// OC3A output: Discon.
// OC3B output: Discon.
// OC3C output: Discon.
TCCR3A=0x00;
TCCR3B=0x00;
TCNT3H=0x00;
TCNT3L=0x00;
OCR3AH=0x00;
OCR3AL=0x00;
OCR3BH=0x00;
OCR3BL=0x00;
OCR3CH=0x00;
OCR3CL=0x00;
// External Interrupt(s) initialization
// INT0: Off
// INT1: Off
// INT2: Off
// INT3: Off
// INT4: Off
// INT5: Off
// INT6: Off
// INT7: Off
EICRA=0x00;
EICRB=0x00;
EIMSK=0x00;
// Timer(s)/Counter(s) Interrupt(s) initialization
TIMSK=0x00;
ETIMSK=0x00;
// Analog Comparator initialization
// Analog Comparator: Off
// Analog Comparator Input Capture by Timer/Counter 1: Off
// Analog Comparator Output: Off
ACSR=0x80;
SFIOR=0x00;
while (1)
// Place your code here
PORTB=0x01;
delay_ms(5);
PORTB=0x02;
delay_ms(5);
PORTB=0x04;
delay_ms(5);
PORTB=0x08;
delay_ms(5);
