How do I use Block RAM in my spartanII based design?
Vonn
Full Member level 4
Full Member level 4
I need to use a Block RAM in my spartan II based design ; this is the first time to use the logic core generator in the ISE5.1 .
I have followed all the steps in the core generator and it's completed successfuly , but after i added the created VHD file to my design I noticed that there is a sub file in the sources window called wrapped_filename ??
and when i tried to compile the generated ram file i have got an error message
"ERROR:HDLParsers:164 - C:/Fndtn/bin/divider/myram.vhd Line 111. parse error, unexpected $ "
Actually line 111 is the end of the generated code and there is no any $ ???
If any body had used the core generator before please give me a hand
The alternative way is to use a pure VHDL code. XST could automatically instantiate BlockRAM directly from HDL code. No need to use CoreGen.
See chapter 2 of Xilinx Synthesis Technology (XST) User Guide.
-- Here is an example for single port BlockRam ---------
library IEEE;
use IEEE.std_logic_1164.all ;
use IEEE.std_logic_unsigned.all ;
entity sync_ram_singleport is
generic ( data_width : natural := 8 ;
addr_width : natural := 8);
port (
clk : in std_logic;
we : in std_logic ;
addr : in std_logic_vector(addr_width - 1 downto 0) ;
data_in : in std_logic_vector(data_width - 1 downto 0) ;
data_out : out std_logic_vector(data_width - 1 downto 0)
end sync_ram_singleport ;
architecture rtl of sync_ram_singleport is
type mem_type is array (2**addr_width-1 downto 0) of std_logic_vector(data_width - 1 downto 0);
signal mem : mem_type ;
signal addr_reg : std_logic_vector(addr_width - 1 downto 0);
begin
Singleport:
process (clk)
begin
if (clk'event and clk = '1') then
if (we = '1') then
mem(conv_integer(addr)) <= data_in ;
end if ;
addr_reg <= addr ;
end if ;
end process singleport;
data_out <= mem(conv_integer(addr_reg)) ;
end rtl ;
Thank you , elektrom ...It works after i modified it to fit with my needs but i faced another problem that is..
i need to connect the data bus of the ram to the output world ( out of FPGA) to the common data bus . So i defined the data in the entity as inout ... but it didn't work ..I mean If you want to guide the synthizer to make it RAM , you MUST put din and dout and if you make it inout the synthizer would never put it as RAM .
If Am I wrong Plz correct my understanding
XST is not so smart. you have to write code in its own style. The solution is cover is ram module by another module. Like this...
LIBRARY IEEE;
USE IEEE.std_logic_1164.all;
ENTITY RAM512x16 IS
PORT(
CLK : IN std_logic;
ADDR : IN std_logic_vector ( 9 DOWNTO 0); -- Address
WE : IN std_logic; -- Write enable
OE : IN std_logic;
DATA : INOUT std_logic_vector (15 DOWNTO 0) -- Data input/output
END RAM512x16 ;
ARCHITECTURE RTL OF RAM512x16 IS
component sync_ram_singleport
port (
clk : in std_logic;
we : in std_logic ;
end component;
signal DIN : std_logic_vector(15 downto 0);
signal DOUT : std_logic_vector(15 downto 0);
BEGIN
U1: sync_ram_singleport
generic map ( data_width=>9,
addr_width=>16)
port map (
clk =>CLK,
we =>WE,
addr =>ADDR,
data_in =>DIN,
data_out =>DOUT
-- Tristate buffer
DATA <= DOUT when OE = '1' else (others=>'Z');
DIN <= DATA;
END RTL;
Good Luck!
search LIB and XST xilinx documents they contains solution to your problems.
To use coregen, you no need to add in the vhd file. xst needs the .xco file.
You can invoke coregen from within ise by : new source=>core gen ip. Then the block ram will be automatically added in your project. It should work as expected.
hi
when you want to use the ram component that you `ve generated with CoreGen you can find the component port definitiion in the vhd file that coregen has created. I have used Dual Port Ram from coregen several times and I had no problem.
I've used the Core generator to have a single Block RAM ; The first lines in the VHDL file
contains an announcment :
-- You must compile the wrapper file ramcore.vhd when simulating
-- the core, ramcore. When compiling the wrapper file, be sure to
-- reference the XilinxCoreLib VHDL simulation library. For detailed
-- instructions, please refer to the "Coregen Users Guide".
ramcore : is the created vhd file and you can see the wrapper_ramcore as file in a sub window
" source in project " as a sub of the ramcore !!
I can't deal with this file ! It's marked by a red quesion mark
and when i click on it , the new window appears as you are creating new source ???
Also The created VHD file can't be compiled and gives the error :
ERROR:HDLParsers:164 - C:/Projects/MyProjects/RAM/ramcore.vhd Line 112. parse error, unexpected $
I have return back to the pdf "Coregen Users Guide" , but I couldn't find the solution for this problem
can any body give me a hand
Please make your post in a steps :
After I have got the vhd file created from the core gen. Knowing that Iam using ISE5.1
What should I do ?
1-
2-
3-
hi
I created the same core(I mean single block memory) and after those commented lines ! it contains the following port definition:
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
Library XilinxCoreLib;
ENTITY test IS
port (
addr: IN std_logic_VECTOR(7 downto 0);
clk: IN std_logic;
din: IN std_logic_VECTOR(15 downto 0);
dout: OUT std_logic_VECTOR(15 downto 0);
we: IN std_logic);
END test;
1. you should put the following code in your top level design:
compnent test
port (
clk: IN std_logic;
we: IN std_logic);
end component;
2. then instanciate the component and use it! thats all!!!
