So you're doing simultaneous harmonic termination for a single frequency ? Right ?I am creating an output match with a fundamental load determined by loadpull, and I read that a short at second harmonic and open at third harmonic would enhance pae.So I was optimising.
Yes I guess that is what I am trying to doSo you're doing simultaneous harmonic termination for a single frequency ? Right ?
In that case, you have to find a matching circuit with related Transfer Function that has zero's and/or pole's at Harmonic Contents. In fact, this problem is a kind of Network Synthesis problem. While requesting a certain Reflection @ f1, the circuit will behave open or short circuit @ harmonics.Yes I guess that is what I am trying to do
If you've already obtained the Optimum Impedance for a target, you can play on this matching circuit by adding Notches or Parallel LC circuits that don't disturb the main function. Even tough there isn't unique technique to realize such circuits, there are many literatures about how to design. I suggest you to seek the literature.Thank you!Is there a tool to determine matching circuit transfer function in ADS ?.I am trying to match at 10GHz.I have the impedance from load pull that gives me the maximum pae at 10GHz.I can easily design the narrowband output match .Howerver the problem is that match to simultaneously match at f1 and harmonics of interest.
