dreadQ
Newbie
hello. I have some problem running Star-RC to make SPEF file during autoP&R (innovus).
I worked on PNR. so I have *.v, *.lef, *.def and .itf .
below script is use. when i extract for SPEF.
But, Running Star-RC causes an error called "ERROR: MACRO statement before any LAYER statement. (SX-2093)"
I think an error occurred in MAPPING FILE.
MAPPING FILE format is as below.
Q1.
How to create a spef file using starRC?
Q2.
I read something, tlu+ can convert mapping file. right?
Q3.
what is the problem about Mapping file?
Q4.
Can i use a Calibre to make SPEF file?
my Front Eng say, spef file delay info is not match.
Please Answer. have a good time.
BLOCK: *
LEF_FILE: *
TOP_DEF_FILE : *
TCAD_GRD_FILE: *
MAPPING_FILE: *
OPERATING_TEMPERATURE: 125
HIERARCHICAL_SEPARATOR: /
BUS_BIT: []
EXTRACTION: RC
COUPLE_TO_GROUND: NO
COUPLING_ABS_THRESHOLD: 0
COUPLING_REL_THRESHOLD: 0
EXTRACT_VIA_CAPS: YES
REDUCTION: NO
XTRACTOR: xTractor
NUM_CORES: 16
STAR_DIRECTORY: *
NETLIST_FORMAT: *
NETLIST_FILE: *
conducting_layers
PO POLY
M1 MET1
M2 MET2
M3 MET3
M4 MET4
VIA_layers
CONT POLY_CONT
VIA1 VIA1
VIA2 VIA2
VIA3 VIA3
Q1.
Q2.
Q3.
Q4.
