How do I integrate an optocoupler into a CAN-bus to isolate one node from the bus?
E-Floyd
Newbie level 3
Newbie level 3
Hello everyone,
I should install an optocoupler into CAN-bus that I can galvanically isolate one of my nodes from the bus. I´ve actually found a right optocoupler already. Still I don´t know how do I connect this between the CAN-bus and the node that I want to isolate. This optocoupler is meant for CAN-bus but there is nothing told in the datasheet how the electrical connection are supposed to do with CAN-bus application.:roll:
The datasheet of the optocoupler is attached to this message.
Thank you for all kind of help!
E-Floyd
  • optocoupler_CAN_bus.pdf
There are many useful CAN bus example circuits, especially in the user install manuals from vendors of CAN bus interface cards.
Here is a link to one --> LINK
At ni.com, there is a range of (expensive!) CAN bus cards. The user manuals explain connections.
It is not too hard to see the places you would connect the Opto-Isolator to Tx and Rx drivers to make a node which drives the bus, and receives signals from the bus, but does not make any current-sinking connection at all.
Hello Darktrax,
thank you for your kind help. What I realised now is that everyone is doing the galvanic isolation between the CAN tranceiver and CAN controller. However I can´t access the node´s electronics so I have to do the isolation between the CAN tranceiver and the CAN-bus. This means that the isolation would be in the middle of the CAN-bus. I think that I have to design some kind of gateway which includes the isolation in itself. The CAN-bus comes from the node into the gateway and comes out from the gateway and continues to the rest of the CAN-bus system. How does is sound for you? Do you have better ideas? This means that inputs and outputs to the isolation barrier are CAN-signals (not tx rx - signals).
Is it a good solution to buy two of these bidirectional TTL-CAN converters and put them in the order of CAN-TTL-TTL-CAN ? Then I have two galvanic isolations in the string and I just connect these converters in series with the CAN-bus. Sounds working idea?
Here are the converters: http://www.deditec.de/en/entwicklungstools/prod/ttl-can-adapter.html
