How do I increase the voltage?
chaitami
Newbie level 2
Newbie level 2
Hello! I'm quite new to the whole design aspect. I'm trying to build my own hand-cranked dynamo battery charger. Since the output of the dynamo is very small, is there anything that I can use to increase the voltage output? Is op-amp suitable for this type of project? Help!! :cry:
just see if this helps. I guess you'll need to change the final output to DC for charger
Thanks! I did think of a multiplier. But I'm searching for a single chip that work as that. Any suggestions?
The multiplier circuit produces a very low output current.
Added after 2 hours 11 minutes:
A generator's output voltage depends on its speeds.
Use gears or a pu;lley to increase its speed to increase its output voltage.
You can use this IC:
KA34063 : Minimum input voltage required : 3.0V, maximum output current : 1.5A
MCP1252 : Minimum input voltage required : 2.0V, maximum output current : 120mA
Goto microchip.com or fairchildsemi.com to find out more ICs.
