How do I get a bias voltage?
aryajur
Advanced Member level 3
San Jose, USA
Bias voltage generation
I need to bias the bulk terminals of PMOS devices to a value lower than Vdd of the circuit. But if I use a resistor divider, the divider branch takes up a lot of current. If I increase the resistance values, they will take up a lot of area !
The voltage pump is the best for biasing for the bulk terminal.
On the other hand , maybe the MOS bias is ok.
Re: Bias voltage generation
use series transistors?
I agree with the latter.
By the way,you can use self-bias.
Remember one thing, we cannot bias the bulk of the pmos lower than the VDD
because it will cause forward bias voltage between source and bulk and will cause the current from the source going into the bulk. And this will cause short circuit between source and drain because they are sharing the same bulk.
Ya I know about the forward bias thing, but since my transistors are in the subthreshold region I have to bias the bulk a little lower than Vdd to reduce the threshold voltage using Body Effect.
Thanks for the replies,
I used series diode connected transistors with a resistor. It worked fine !
Thanks
