How do I enable the ZDA NMEA message?
john2053
I am using the u_blox8_M8 module GPS Antenna and getting the message in other forms but I want to get the ZDA structure message so that I could display it in LCD?How can I do that?
Hello!
A good start is to read what has been written on the subject. You can read the ZDA string exactly as you
can read other strings. With a bit of adaptation if you want to change GNSS to ZDA. See link below.
Have fun!
that was all about displaying the GPS data as it is(GNSS) extracted from the GPS module. I want to extract only in the format of ZDA so that it will be easy to display.
