Xc = 1 / 2 PI() F CHow do we determine the value of the coupling capacitor in a power amplifier design?
yes it is very difficult, particularly high capacitance values with high SRF, Is it possible to get a 1000pF capacitance with SRF close to 4GHz?It's an arguable question.
The capacitor might be a part of matching OR it may act a simple coupling capacitor.
In any case, the capacitor should chosen very attentively. SRF, Current Handling Capacity, Voltage Handling Capacity, Temperature Characteristics, Tolerance, Case etc. all have to be taken into account.
Therefore the question has a particular answer.
Yes, it's possible. For instance;yes it is very difficult, particularly high capacitance values with high SRF, Is it possible to get a 1000pF capacitance with SRF close to 4GHz?
Why do you want (or need) that? You want low series impedance at your operating frequency, so check if you can reach that goal with smaller C values. Look at capacitor measured data (S21), that is more relevant for your case than the exact C value.Is it possible to get a 1000pF capacitance with SRF close to 4GHz?
I didn't get you, can you please elaborate.Why do you want (or need) that? You want low series impedance at your operating frequency, so check if you can reach that goal with smaller C values. Look at capacitor measured data (S21), that is more relevant for your case than the exact C value.
indeed. if the capacitive reactance is less than say 0.1 ohms....you are good to goXc = 1 / 2 PI() F C
