How do I convert a decimal fraction into binary fraction?
alangs
Member level 3
Member level 3
india
How do I convert the decimal fraction (0.859375)10 into a binary fraction???
0.859375 isn't a fraction. There is an example of conversions for numbers less than unity here:
Keith.
Multiply by 2 as the link above.
But 0.859375 = 55/64 then just shift right 55 binary 6 times.
0.859375 = 0.110111
An easy way is to convert to hex first and then convert hex to binary.
Multiply by 16
write down the integer portion in hex (12 = C, 14 = E, etc)
subtract the integer portion from the result
multiply by 16
continue until the fractional portion = zero, or you have enough accuracy.
For your example:
.859375 X 16 = 13.75 (Write down "D")
13.75 -13 = .75
.75 X 16 = 12 Write down "C")
The fractional part is now zero, so you're done
The answer in hex is DC = 11011100 binary
If you have a scientific calculator with a "Hex" mode, and you are satisfied with 4 hex digits of accuracy, do the following:
In decimal mode, multiply the fraction by 65536.
.859375 X 65536 = 56320
Switch to "Hex" mode.
DC00 is displayed.
Remember, if you are using twos complement representation, the binary result must be shifted right 1 place to make room for the sign bit.
Regards,
Kral
