Hishamsaleh
Full Member level 1
Hi all,
in one of the last postes (not in this category) i found a similer guestion.. but with no right answer,,, I think that ppl didn't get the point of the question...
I know there is 2 axis in each mose to locate x-y motion... but for the singel axis.. i want to know how dop mice knew if the wheel is moving forward or backward...?
as you can see in the picture down, on each axis there is a transmitter and reciever... and wheel with about 36 hole that let transmitted beam to transmit to the resiever... so when the wheel moves, the beam recieved signal goes to be 1 0 1 0 1 0 1 0 1 like this... but what is the technique used to let the detector knows if it is moving clock wise or untic/w...
thanks in advence
thanks in advence
