How dimension a Resistor
roiberts
Junior Member level 1
Dear Forum
In my design, a resistor need to dissipate 100mW ,so,normally i diemnsion it for 1/4w
Now,i have this dilemma:
2 test signal ,of not ordinary value , nust be considered. :
Test 1 signal create a 0.5w for 60second on my resistor
Test 2 signal create a 1.5w for 5 second on my resistor.
Qestion is:
What power is more important = What resisir i buy = 1.5w oe 0.5 ?
Thanks
Roberto
I think you need to use a resistor greater than 1.5W. 5 seconds is a long enough time for a resistor to get damaged from being over-powered. It might be something as subtle as a resistance change, or it may affect its life.
At least, that's what I would do.
Thanks for reply
Could be intresting to know what influence have a overpower of tot
second on the life of a resistor...
What calculation or data can i use for get a idea of this effect….
Thanks again
Roberto
Resistor Manufacturers publish "Admissible Power vs. Pulse Width" curves. in their datasheets.
You can refer them to understand what kind of resistor you have to use.
i agree with barry
1.5W for 5 seconds is more than enough to fry the resistor
use a 2.5W or 3W, depending on easy availability.
if its wire wound, you probably want a non-inductive resistor
