How complex numbers and Laplace transforms helps in solving electronics problems.
iVenki
Member level 3
Member level 3
How complex numbers and Laplace transforms help us in solving electronics problems.
If you are learning about complex numbers and transforms in mathematics and if you don't know the why you learn those then you see this article that I have published in my blog
Electromathematics
I need your feedback on that article.
if you want to analyze the R L C circuit .....the reactive impedances will be always in the imaginary numbers .....also to find out the transfer function of system one need transform operations
Good Luck
Come on. Someone follow my blog please. Only then I can continue my blog. You may find understanding complex numbers and laplace transform easy.
Please guys. I can't continue my blog without a person following it. At least one of you join please.
I advise using pictures/illustrations. Also, a latex/math package to generate the equations. Likewise, plots of functions where applicable.
Thank you for your suggestion.
