How common data bus is used internally in RAM chips
milan.rajik
Banned
This is regarding to 8085 memory interfacing. In many books and other sources they mention that a RAM chip like 8K X 8 will have a CS pin connected to higher order address lines through address decoder circuit. A WR bar and RD bar lines which connect to Input tristate buffer and output tristate buffer. They also mention that there will be 8 input data lines to store data into RAM and 8 output data lines to read data from RAM but externally there will be only 8 bi-directional data bus. I want to know how the 8 input data lines and 8 output data lines are combined internally.
hi,
Internally the 8051 Port pins are set by the program as Inputs or Outputs, depending upon whether its a Read or Write operation from the external memory.
Likewise the external memory IC will set its pins to Input or Output depending upon the WR & RD control pins set by the decoded program instruction, also CS is used to select a specific external IC.
Is this what you are asking.?
E
At least the question title is referring to internal design details of the SRAM.
It's quite easy to split a bidirectional bus into unidirectional busses by means of buffers, using the /RD or /OE line as tristate signal. In so far I don't see a specific problem with this operation. It's probably more interesting how the bus and address lines are translated to word and bit lines interfacing the elementary RAM 6-transistor cell.
I know how a tri-state buffer works but I have problem in understanding how a tri-state buffer works in this context (RAM interfacing). Can you provide a detailed block diagram on internal of RAM chip used for 8085 interfacing ? What happens if both /WR and /RD (/OE) lines are made low at the same time ? Tri states at input of RAM and output of RAM will be enabled ? what is the result? Will there be a circuit in side RAM chip to avoid this condition ?
Examples of internal RAM design can be found in digital IC design text books, I presume. It's also briefly answered in RAM datasheets. See e.g. this block diagram from a Hitachi HM6264. A datasheet also precisely answeres your specific question about /OE and /WE relation. Usually /WE takes precedence. A 8085 (or other processor) won't ever assert both signals simultaneously as far as I'm aware of. In so far it's a purely theoretical question.
