How can we print the pad only for smd, in eagle ?
varunme
Advanced Member level 3
hw can print the smd pads only in eagle ?, i meant which layer ? , is it bcream ?, when i print i prints boxes with white slant line inside ....
yes, i solved, when i export the image it doesnt work , but when i print directly, it worked, tstop and bstop
Be aware that those layers will not be exactly the same size as the copper depending on the settings in the DRC. I cannot check at the moment but there is a pad layer (17 or some other low number between 17 and 21) but I cannot remember if that also includes through hole pads.
Keith
Reactions: varunme
    varunme
