How can we increase the speed of a CMOS hysteris comparator ?
Re: Comparator Speed
Comparator response can be improved by adding hysterisis equal to or greater than amount of largest expected noise amplitude.
Ways to introduce hyterisis is by external method and internal method..
Maybe the speed is better with internel method coz it does not require external feedback.
is hysterisis has impact on speed ?
Syukri
please provide some reference material.
thanks in advance,
Why? Why extrernal feedback may cause the drop of speed?
Comparator Speed
As far as I know hysteresis helps in reducing the effect of noise. To improve speed, the current must be increased.
However, as the tail current increases, the width of the hyesteresis window increase.
you can increase the gain of your input stage as much as possible high enough ,so that you can achieve your speed in the forthcoming stages.
Yes
The hysterisis means there is positive feedback, which will increase the speed
A few ways to improve rise/fall time of comparator:
1. Increase comparator gain. ie gm, Rload
2. Increase current.
3. Positive feedback.
4. Add buffer (inverters)
Positive feedback doesn't means having hysterisis.
But having hysterisis means have positive feedback :)
What kind of comparator ? Continuous or clocked ?
If continuous, what you really really want is to have fast time constants, so use a cascade of low-gain, fast stages (say 3 or 4) to obtain the fastest possible response.
If clocked, make the latch devices ultra-short and keep capacitances small, so that the regeneration is fast. Your offset will be bad, but it's possible to design around it.
Hysteresys helps reject noise, in continuous comparators. It's a problem in flash ADCs, so it depends on what you want the comparator for. If there's hysteresys, then you have positive feedback, but you won't always have better speed because of hysteresys in your comparator...
How looks a "clocked" comparator ? It's the first time I heard this terminology.
A comparator is a comparator. If has other tricks to increase the output switching speed and minimise jitter is not anymore a simple comparator but a comparator followed by a digital logic circuit...
You may refer to the book Analog Integrated Circuit Design, David Johns & Ken Martin regarding detailed clocked/latch comparator.
Comparator Speed
I designed the comparator with hysteresis internal, but I found the gain of the comparator is low. Is it supposed to be that way?
