How can we embed an audio channel in SDI video stream ?
pourfardm
Junior Member level 1
IRAN
SDI (embedding audio)
How can we embed an audio channel in an SDI video stream ?
Re: SDI (embedding audio)
you need to sample the audio channel to digital AES\EBU Format, then
to translate it to SDI Form. the embedding rate is the sample rate - usually 48khz
multiply by 32 x2, but you need to embedd with 27mhz clock, thus a small fifo is needed.
