how can use hspice in cadence ic50?
yankuangtu
Member level 3
Member level 3
i set the hspice in the ic50_install_dir correctly and can create the hspice netlist rightly,but can not simulate the circuit use hspice in ic50--install under redhat8.
thank u:)
Make sure you have hspice license
May be u should set your simulator to HspiceS.
you need to patch your red hat 8.0 ...you can get the patch file from redhat website
I have try ic5.0 .. It can't support the hspice GUI interface ..
THis is different witth UNIX 4.6...
It works fine with me. Take a look at your setup
You need both installing hspice soft-pack and hspice interface license for IC50.
hspice simulator is not one part of IC50 except its interface.
