How can I use serial port by using C# in Windows XP?
bader
Member level 1
Member level 1
serial port using c#
hi ........
how can i use serial port by using c# in windows xp..........
Re: serial port using c#
hi
will if u will make a windows forms application u can easily use the mscomm activex tool ............u will find it on the add/remove too box with the name of microsoft communication ............then u just use it like any other control
I was searching for driver access for .NET a year back. Couldnt find any. In the end, used PInvoke to call winAPI functions. Worked great!
If you are using .NET 1, you must use P/Invoke or get an ActiveX control to do that. (Look at CodeProject for the P/Invoke case).
If you use NET 2.0 Beta you get classes to access the serial ports included in the framework. I've used them and they work :).
You can't use Visual Studio 2003 with the .NET 2 Beta, so, use Visual Studio Express ( free ) or get a beta of Visual Studio 2005.
Hope this helps you
I am new to Visual C#.NET.
I need to connect an XML sending device to the COM port and read and write data to it.
Hi, i would like to know how i can access the COM port in Visual C#.NET either in the Windows Application (prefered) or Console Applicaion.
I am using the 'Visual Studio .NET 2003'.
Kind Souls please help...
