how can I use int0 and int1 at a time with atmega8???
Mithun_K_Das
Advanced Member level 3
Dhaka, Bangladesh, Bangladesh
read this program. its working well with int1. tell me how can I use both int0 & int1??
int cnt = 0, cnt2 = 0; // Global variable cnt
void interrupt_ISR () org IVT_ADDR_INT1
{ // Interrupt rutine
SREG_I_bit = 0; // Disable Interrupts
cnt++;
PORTD = cnt; // Increment variable cnt
SREG_I_bit = 1; // Enable Interrupts
void interrupt_ISR () org IVT_ADDR_INT0 // Look here. how can I call/enable
intrrupt 1?
cnt2++;
PORTC = cnt; // Increment variable cnt
SREG_I_bit = 2; // Enable Interrupts
void main()
{ // Main program
DDRD = 0b00110011; // Set PD3 as input
DDRB = 0xFF;
DDRC = 0xFF; // Set PortB as output
//PORTD = 0x00;
PORTB = 0xFF; // Starting value for PortD
GICR = 0x80; // Set the Interrupts
MCUCR = 0x08; // Configure Interrupt for falling edge on PortD.3
while(1)
{ // Unending loop
PORTB = 0xFF;
Delay_ms(10);
PORTB = 0x00;
Delay_ms(10);
// Write on PortB value of varibale cnt
Try with this code:
void interrupt_INT1() org IVT_ADDR_INT1
cnt++;
void interrupt_INT0() org IVT_ADDR_INT0
cnt2++;
void main()
{ // Main program
DDRD = 0b00110011; // Set PD3 and PD2 as input
DDRB = 0xFF;
//PORTD = 0x00;
PORTB = 0xFF; // Starting value for PortB
GICR = 0xC0; // Set the Interrupts - INT0 and INT1
MCUCR = 0x0A; // Configure Interrupt for falling edge on INT0 and INT1
while(1)
{ // Unending loop
PORTB = 0xFF;
Delay_ms(10);
PORTB = 0x00;
Delay_ms(10);
I think you can understand how I did it. I set the values of GICR and MCUCR. If you read the datasheet and understand, then it should be clear. I also think you can understand how I set the interrupts.
Hope this helps.
Tahmid.
It is possible to group interrupts, however I can't remember how it is done, check avr-gcc compiler documentation. Anyway, the controller itself have interrupt priorities, so one, which has higher priority, will interrupt the lower one :)
The interrupt priority depends on the location in the interrupt vector table (IVT), so if INT0 and INT1 interrupts occur at exactly the very same moment, INT0 ISR is served first, then INT1 ISR. This, however, won't cause much errors, as the delay will be in the order of a few microseconds (if not nanoseconds) - or atleast it should be, since you should always keep the ISR very short.
Hope this helps.
Tahmid.
The ISR can be long enough if other interrupt will interrupt the going one and then it will be back for the previous interrupt routine, just don't disable interrupts inside interrupt :)
Yes. Don't disable interrupt in the ISR. I've removed that bit from the code I posted.
Tahmid.
Thanks Tahmid. You really done a great help in my learning session. thanks again. its working...
---------- Post added at 17:17 ---------- Previous post was at 17:16 ----------
have you any idea about 'extreme burner' for avr series?
