How can i test a code that its input is integer values
enga3b2
Junior Member level 1
Hello All,
Kindly i wanna know How can i test a code that its entity input is integer values on spartan3e kit
Thanks
You cant give inputs as integers directly.You have to convert them into binary values and input them into the FPGA using switches avalilable in the board.
Suppose you have a value 17 (10001 in binary) to be input into the code running on the kit.Then keep the 5th and 1st switch ON and all others OFF.And press a pushbutton to inform the processor that input is ready to be captured.Your code has to be modified for this.It needs an additional signal "pushbutton_pressed" or something like that.
--vipin
https://vhdlguru.blogspot.com/
Thanks :D
But I have only 4 switches on the spartan3e kit and i need more than these if i converted them to binary, so if you know any other solution kindly reply me.
Also i have 3 crystals on the kit and i don't know how to configure any of them to use it as a clock! can any one help in this?
say you have 8 bits input to your entity.But you have only 4 switches.so 4 values can be input at a time.This can be done with the help of push buttons.
if (pb0 = '1') then
  input(3 downto 0) <= switches(3 downto 0);
elsif (pb1 = '1') then
  input(7 downto 4) <= switches(3 downto 0);
end if;
Here pb0 is the first push button, and pb1 is the second push button. First set the switch values so that LSB 4 bits are entered.Then press push button 0.
Now change the switch values for MSB 4 bits.This time press push button 1.
This can be extended for any amount of bits.The main idea is that use push buttons and switches together.
--vipin
