How can i solve second order nonhomgeneous differential equation?
m.mohamed
Member level 1
Member level 1
I would like to solve a non-homogeneous differential equation with complex coefficient. The equation is in the form:
where Jx is not a function of z and k, w, u are constants
\[ E_x = j \omega \mu {J_x} + A(1-cos( \sqrt{k} t) + B \sin( \sqrt{k} t) \]
Thanks for your replay Eduardo, can you send to me the method of solving?
My apologies for the k and z's forgotten in the previous message.
If Jx does not depend of z it can be treated as a constant in the differential equation, then the solution is the sum of one particular solution
\[E_{xp} = \frac{j \omega \mu\,J_x }{\sqrt{k}}\]
plus the solution of the homogeneous
\[E_{xh} = A\cos(\sqrt{k}z)+B\cos(\sqrt{k}z)\]
\[E_x = E_{xh} + E_{xp}\]
Eduardo, on your Exp there is sqr("k"). In my approach there is none.
a=j·w·mu·Jx
you mean in this case that the imaginary part of the particular solution dosn't matter, does it?
i think when the right hand side of the particular solution is complex, the method of solving will be different, is it right??
CataM, Ex is differentiated with z , so why you write the solution as a function of x?
