How can I simulate a program which is written in SystemC?
dariush
Member level 1
Member level 1
Hi
How can I simulate a program which is written in systemc?
How can I create waveforms for my simulation?
bye
systemc-2.0.1.exe
There exist commercial simulators which treat SystemC just like VHDL or Verilog.I think Active-HDL is offering that and Modelsim too (not sure about the second). If you do not have them or you do not have money to spend you can use the free simulation kernel which is distributed from www.systemc.org (OSCI) and use any C/C++ compiler you like to perform simulation. To see waveforms you can make a VCD dump file during simulation, using SystemC calls, and view them after simulation with an open-source VCD viewer.
Read the manual and the discussions in www.systemc.org and you will find all you want.
systemc trace vcd file
Hi geconom
How can I download OSCI and use it?
I can simulate my files and create VCD dump file.
after that what should I do?
thanks
bye
install gtkwave systemc
OSCI is Open SystemC Initiative or something like that. Just go to https://www.systemc.org and download the latest core language package and the documentation for your platform. As for the VCD viewer, go to **broken link removed** and get GTKWave. If you tell me the platform you are using (Windows, Linux, Solaris), I may offer more help.
ghraib 2.0.1 exe
Hi geconom
My platform is windows NT/2000.
thanks
bye
vcd file for systemc
install.
systemc viewer
modelsim5.8 easy to use.
.vcd convert to .WLF
vcd2wlf <source.vcd><target wlf>
gtkwave for solaris 10
hi guys ..
how can i make a VCD dump file if I'm using VC++ 6 for compiling SystemC ..?
and if I have Modelsim .. how can I view the waveform using it ?
create file.vcd with systemc
I've downloaded Gtkwave from h**p://www.cs.man.ac.uk/apt/tools/gtkwave/ and I tried to install in Cygwin environment but without success. There is something happen but I don't know why. The problem happen in ./configure process.
Here is the message:
"The glib-config script installed by GLIB could not be found ... "
create dump file with systemc
if u r using Vc++ ,
in the main.cpp
u have to create VCD file ,
sc_trace_file *filepointer_name = sc_create_vcd_trace_file("output")in that vCD file u have to trace the signals which u want to see
sc_trace(filepointer_name,signal name,"name of the signal u want to see in the output");
