use tools->CDF then choose the cell to edit the parameter, you can see the interpreted labels information-> opPointLabelSet is id vgs vds, you can change that.
also you should notice the CDF type, effective means just change for current using,If you exit icfb, the setting will lost.If you want to change the CDF permenantly, choose base. Further help can be get from the openbook.
