WayneF said:
HolySaint said:
If STA is on Functional mode, just disable the Test mode by setting the case analysis on the respective test pins(scan_enable, scan_mode pins) which enable/disables the Testing.
i do it as u told me
but there are more violation as i analysis dc netlist (i use pt)
why ?
What are those violations? Can you give a couple of examples?
Startpoint: e1446_reg_2_
(rising edge-triggered flip-flop clocked by clk8)
Endpoint: twnc_core/down_top/down_core/dagc/err2out_read_tmp_reg_43_
Path Group: clk8
Path Type: max
Point Incr Path
clock clk8 (rise edge) 0.00 0.00
clock network delay (ideal) 0.00 0.00
e1446_reg_2_/CK (SDFFRHQX1)
0.00 0.00 r
e1446_reg_2_/Q (SDFFRHQX1)
0.26 0.26 r
U193579/Y (INVX1) 0.13 0.38 f
U252239/Y (INVX1) 0.18 0.56 r
U252238/Y (INVX1) 0.24 0.80 f
U197310/Y (INVXL) 0.74 1.54 r
U196532/Y (INVX1) 0.31 1.85 f
U306728/Y (OAI21XL) 0.18 2.04 r
U306727/Y (OAI21XL) 0.17 2.20 f
U196286/Y (OAI2BB1X1) 0.18 2.38 f
U306556/Y (OAI21XL) 0.10 2.48 r
U196287/Y (INVX1) 0.12 2.60 f
U196290/Y (OAI2BB1X1) 0.14 2.73 f
U306548/Y (OAI21XL) 0.10 2.83 r
U196291/Y (INVX1) 0.12 2.95 f
U196275/Y (OAI2BB1X1) 0.14 3.09 f
U306557/Y (OAI21XL) 0.10 3.19 r
U196276/Y (INVX1) 0.12 3.31 f
U196292/Y (OAI2BB1X1) 0.14 3.44 f
U306549/Y (OAI21XL) 0.11 3.56 r
U193304/Y (INVX2) 0.08 3.64 f
U193542/Y (OAI2BB1X1) 0.13 3.76 f
U193541/Y (OAI21XL) 0.10 3.86 r
U196279/Y (INVX1) 0.12 3.98 f
U196288/Y (OAI2BB1X1) 0.14 4.12 f
U306550/Y (OAI21XL) 0.10 4.22 r
U196289/Y (INVX1) 0.12 4.34 f
U196277/Y (OAI2BB1X1) 0.14 4.48 f
U306558/Y (OAI21XL) 0.10 4.58 r
U196278/Y (INVX1) 0.12 4.70 f
U196269/Y (OAI2BB1X1) 0.14 4.83 f
U306551/Y (OAI21XL) 0.10 4.93 r
U196270/Y (INVX1) 0.12 5.05 f
U196280/Y (OAI2BB1X1) 0.14 5.19 f
U306559/Y (OAI21XL) 0.10 5.29 r
U196281/Y (INVX1) 0.12 5.41 f
U196271/Y (OAI2BB1X1) 0.14 5.54 f
U306552/Y (OAI21XL) 0.10 5.64 r
U196272/Y (INVX1) 0.12 5.77 f
U196282/Y (OAI2BB1X1) 0.14 5.90 f
U306560/Y (OAI21XL) 0.10 6.00 r
U196283/Y (INVX1) 0.12 6.12 f
U196273/Y (OAI2BB1X1) 0.14 6.26 f
U306553/Y (OAI21XL) 0.10 6.36 r
U196274/Y (INVX1) 0.12 6.48 f
U196284/Y (OAI2BB1X1) 0.14 6.62 f
U306561/Y (OAI21XL) 0.10 6.72 r
U196285/Y (INVX1) 0.12 6.84 f
U196293/Y (OAI2BB1X1) 0.14 6.97 f
U306554/Y (OAI21XL) 0.10 7.07 r
U196294/Y (INVX1) 0.12 7.19 f
U306564/Y (OAI2BB1X1) 0.14 7.33 f
U306563/Y (OAI21XL) 0.10 7.43 r
U306562/Y (INVX1) 0.13 7.56 f
U193263/Y (OAI2BB1X4) 0.10 7.66 f
U306555/Y (OAI21XL) 0.09 7.75 r
U194190/Y (INVX1) 0.14 7.88 f
U193818/Y (OAI2BB1X2) 0.12 8.01 f
U193817/Y (OAI21X2) 0.08 8.09 r
U196724/Y (INVX1) 0.09 8.17 f
U193258/Y (OAI2BB1X2) 0.10 8.28 f
U193427/Y (NAND2X1) 0.17 8.44 r
U194158/Y (AOI2BB1X1) 0.15 8.59 r
U194157/Y (NOR2X1) 0.12 8.71 f
U196306/Y (OAI2BB1X1) 0.17 8.88 f
U196486/Y (NAND2X4) 0.08 8.96 r
U193883/Y (INVX1) 0.13 9.10 f
U193266/Y (OAI21X4) 0.15 9.24 r
U193265/Y (CLKINVX8) 0.05 9.29 f
U193457/Y (OR2X2) 0.10 9.39 f
U193456/Y (NAND2X1) 0.20 9.59 r
U194179/Y (OAI21XL) 0.11 9.70 f
U193257/Y (NAND2X2) 0.14 9.84 r
U194180/Y (INVX1) 0.15 9.99 f
U193269/Y (OAI21X4) 0.16 10.15 r
U193267/Y (CLKINVX8) 0.05 10.20 f
U196235/Y (OR2X4) 0.10 10.30 f
U196236/Y (NAND2X4) 0.07 10.38 r
U193882/Y (INVX1) 0.14 10.51 f
U193277/Y (OAI21X4) 0.16 10.67 r
U193275/Y (OAI21X4) 0.04 10.71 f
U193276/Y (OAI2BB1X4) 0.08 10.79 r
U196328/Y (INVX1) 0.11 10.90 f
U196338/Y (OR2X4) 0.12 11.03 f
U193816/Y (NAND2X4) 0.07 11.10 r
U193468/Y (OAI21XL) 0.08 11.18 f
U193467/Y (NAND2X1) 0.28 11.46 r
U193300/Y (OAI21X1) 0.11 11.56 f
U196488/Y (NAND2X4) 0.14 11.70 r
U193261/Y (CLKINVX2) 0.14 11.84 f
U193272/Y (OAI21X4) 0.14 11.98 r
U193270/Y (OAI21X2) 0.07 12.05 f
U199798/Y (OAI21X4) 0.10 12.15 r
U196451/Y (INVX1) 0.12 12.27 f
U194292/Y (NOR2X1) 0.11 12.39 r
U193543/Y (OR2X2) 0.16 12.54 r
U193546/Y (OAI21XL) 0.09 12.63 f
U193544/Y (NAND2X1) 0.23 12.85 r
U193547/Y (INVX1) 0.13 12.98 f
U196954/Y (OR2X2) 0.13 13.11 f
U194293/Y (NAND2X1) 0.16 13.27 r
U196221/Y (INVX1) 0.14 13.41 f
U196723/Y (OAI21X2) 0.19 13.60 r
U306326/Y (OAI21XL) 0.13 13.74 f
U193278/Y (OAI21X4) 0.14 13.87 r
U193821/Y (OAI21X4) 0.04 13.92 f
U193820/Y (OAI2BB1X4) 0.10 14.01 r
U306353/Y (OAI21XL) 0.10 14.11 f
U196212/Y (NAND2X2) 0.12 14.23 r
U196198/Y (INVX1) 0.09 14.32 f
U306412/Y (XNOR2X1) 0.12 14.44 f
U306411/Y (OAI21XL) 0.14 14.58 r
U306410/Y (OAI21XL) 0.08 14.66 f
err2out_read_tmp_reg_43_/D (SDFFRXL)
0.00 14.66 f
data arrival time 14.66
clock clk8 (rise edge) 15.00 15.00
clock network delay (ideal) 0.00 15.00
clock uncertainty -0.20 14.80
err2out_read_tmp_reg_43_/CK (SDFFRXL)
14.80 r
library setup time -0.16 14.64
data required time 14.64
data arrival time -14.66
slack (VIOLATED) -0.02
in dc netlist, the timing can meet
when dff-->sdff,the timing is becoming tighten
but should i inprove my timing in dc scripts?
