arsenal
Full Member level 2
as shown in the attached pic,
R1 is to pull down the node of v3,
switch s1 will be on for sometime and c1 will be charged to vdd=1.5v
then s1 will be switched off, and v2 will be decreased from vdd,
when v2<v1-vtp, then v3 will turn on N1 and v4 will be pulled down,
and the problem is when v2 is going down and P1 is on, then c1 will be
discharged and v1 will decrease(s1 is off), then if v2 decrease slower than
the time constant of c1.(R1+Rp1), then v3 will never be high enough to turn
N1,(C1 is integrated, so it can not be large)
then, how can i hold the charge at v1 without using amplifiers ? thanks a lot
