Thanks but... how?laktronics said:Hi,
These instruments with pulse output will mostly provide a pulse for fraction of KWH measured, which you can integrate by counting using for example a microcntroller and use in your application. The device thus can be used as a KWH sensor as well as a display unit for your cross verification if required.
Regards,
Laktronics
