hobbskw
Junior Member level 3
Greetings,
I appreciate the help you have all provided me in the past. I have run into a mistake on my PCB, which cannot be fixed in the software because we encountered this problem after it has already been manufactured and shipped and it is too expensive to simply order a redesigned board. Basically, these connections are backwards. I had connected VP to the VN pin, and VN to the VP pin.. So, I was wondering if there is any way to swap these connections, such as by soldering a cable of some sort? Are there cables specially made for this? How would you remove the incorrect connections? It is a messy situation that I would prefer to not be in, and I don't expect any elegant solution. I would greatly appreciate any help!
I attached and linked an image to the pins. The capacitor is an 0805 capacitor.
I apologize for putting this in the wrong section. Should not be in the software/simulation section.
--- Updated ---
