how can i program at89s51
eng.elgendy
hi
i having project by at89s51 and i didn't knwo how can i program it?
please i need help
regards
elgendy
what do you really need?
software or hardware?
Nandhu
Hi Nandhu
thank's for your reply
and i need hardware connection of at89s51 using at89c2051 and rs232
regards
elgendy
for programming 89C51 first you need the hardware kit which can download the code from PC to your MCU(its called Programmer).
and secondly you need software tool which can help you to create the file which can be dowloaded in you MCU(its called EDITOR or IDE).
you can find both easily on GOOGLE.
Hi eng.elgendy
do u need to Programmer only for AT89S51 .
if so i ll send the Hardware(schematic) That can be used for programming the controller
Hi prabakaran
ya i need Programmer for AT89S51 and it's hardware(schematic) .
my project is design plc device (programmable logic controller) , this mean that i need to download aprogram and then clear it then download another program and so on several times at board without remove the chip so i need to use
at89s51 .
regards
elgendy
you can search it in this board , you will get , lots of schematic , software etc.
**broken link removed** - at89s52
hello all, this is the true link.
thanks syrax, thats nice link.
and it has USB Programmer also.
Here is the link refeer it lot's of tutorial's you can find
i check this 89c5131 chip but the price in Bulgaria is about 10 euro i think this is very powerfull chip
