How can I possibly reduce the power dessipation
opins
MPPT
Hi every one,
I have just built a 40V, 5A, Maximum Power Point Tracker, using a buck topology, and it works considerably well, especially for low sun conditions.
I used P Mosfet for the switching, and complimentary transistors (BC639 and BC640) as the mosfet gate driver.
My problem the Mosfet gets very hot at mid switching condition.
How can I possibly reduce the power dessipation?
I also want to build another circuit for 50V, 10A load
My problem is how to get a about 3mH, that can withstand morethan 10A?
can I use double inductor?
e.g If i have a 4mH, 6A dual inductor (please see attached), can i parallel the leads to get 2mH, 12A inductor?
I have attached a picture of the inductor I used for the previous circuit
MPPT
why is the inductor getting hot? typically it will only get hot if there is a lot of current flowing when there is still voltage across the device.
this will either be due to I^2 R losses (Rds_on too high), or due to a fast switching rate -- on each cycle there is some amount of overlap between voltage falling and current rising, which means some amount of energy lost per cycle.
P-FETs tend to do worse in both regards. Perhaps you should look into using an N-FET. look up high-side gate drive schemes.
for inductors, yes, you can use 2 discrete inductors in parallel.
MPPT
You are showing a common mode choke. it's not suited as DC converter inductor, because it's getting saturated. Generally, I don't understand why you want to use such a high inductance. It would be only reasonable for low kHz switching frequencies.
Re: MPPT
thanks for your response,
N mosfet for low side switching buck converter? the issue is that i have not seen a comprehensive literature on that. but I will still search further.
I may probably try using a mosfet gate driver IC, will that reduce switching losses (switching freq is about 15Khz)?
I use large inductance because i want it to operate in continuous conduction mode, and also, the switching frequency is about 15Khz (I use low freq bcos the mppt tracking circuit utilises ripple correlation)
MPPT
N-FETs have been used for that purpose for a long time -- its also common to see the buck converter used with SCRs/Triacs (for AC), with IGBT's, or with other devices.
The large issue is with ground loops -- the output is connected between Vcc and the FET's drain. thus if the output's negative terminal is connected to a system ground by accident, it essentially shorts across the FET, removing all control from the circuit.
at 15khz, switching losses should be very low for many commercially available FETs. Rds_on and the I^2 R losses in the inductor will likely be the large sources of loss.
and as mentioned, you can also make a high-side driver for an N fet.
