How can I pass parameter to a *.tcl file
madhusudhan_prabhu
I want to pass parameter to a tcl file.
e.g.
test.tcl file contains:
set i [lindex $argv 0]
When I use the following command : source test.tcl 9
on the TCL prompt it gives an error.
tcl prompt:
% source test.tcl 9
wrong # args: should be "source fileName"
Please somebody help me.
Regards,
Madhusudhan Prabhu
Hi Madusudan,
Can you provide complete script here,that will help to find out issue with that script.
Source will accept only one argument that is script name only.
If you want execute the script, just give executable permissions to the script.
If you are in tcl shell,
tcl> exec test.tcl 9
You will have your required o/p.
If u r in unix shell.
unix>./test.tcl 9
Thanks
Teja
