How can I make a usb mobile phone charger ?
makri
Full Member level 2
Full Member level 2
India, Kerala
How can I make a usb mobile phone charger!!
pl help
Re: usb mobile phone charger
Very simply you could just use a Zener diode resistor arrangement.
You can sink upto 500mA from USB port.
So get a zener for the voltage needed to charge the phone.
Set up as follows VCC--Resistor---Zener---Ground.
May work
Only took 2seconds to dream up :angel:
It is easy,give you a sample:
Well this would not work I don't think !!
Mobile phones contain their own charging circuit don't they
So all that is needed is the correct voltage supply the phone will do the rest
