snaider
Member level 5
Make a Compiler
How can I make a compiler program, with a grafical interface, a empty sheet, where you write the code, it has to read the code a check his sintaxsys, and make a output file in a tx, it this is like tranlating the code, which languge is where any example or GNU program like that.
