u can add a autorun in a easy way
just add a notepad and save as "Autorun.inf"
open it and add the following
[autorun]
open=autorun.exe
icon=autorun.exe
open ----> is the path where ur exe is, if it is at the same location where the inf file( in the root ) then simply specify name of the file, else provide the path.
icon ----> to specify the icon u want to display.
for boot
u can find some third party utility tools in the net.
the best way is to go to google and search " creating bootable cd"
and you may need auto run Menu for several setups. then you use AutoPlayMenu Studio, Maestro CD Auto Run Menu. But "bootable" cd image soo small. about 2 Meg
The basic bootable image on a bootable CD is of a 1.4M floppy disk -o), so yes it is limited.
If you go to http://www.nu2.nu/bootcd/, Bart's approach copies the 'floppy' image to Ram disk then loads drivers and allows access to the rest of the CD. This works just fine, I've used it to create a bootable CD for my laptop which doesn't have a floppy drive and can't boot from a USB memory stick.
Also, Nero can create bootable CDs, but I've never tried this so don't know if it works.
In Nero you can make a bootable CD, the only thing you need it's a bootable floppy, you select bootable CD from the menu and i'll ask you for the floppy.
If you like the cd open a program when boots you can edit with notepad the autoexec.bat from the floppy and add you program path at the end of the file.
When I boot from a CD that is for a specific corporation, there is a menu that you can select boot from harddisk or boot from CD-ROM. Above this menu there is the name of the corporation.
Now, how can I change the name?
