How can I link an vs2005 built lib with evc4???
john2020
Full Member level 5
Full Member level 5
evc4 vs vs2005
Hi all,
Anybody use evc4 to link an vs2005 built static library? The
compiler errored when linking with error message of incompatible c
runtime library. Anybody know how to solve this problem, I can't use
an .dll in my project ...
Thanks,
john
:). I think this defines your problem:
incompatible c runtime library.
eVC4 is a cross compiler (meaning it compiles code for another type of CPU on your PC's CPU). Therefor it is very likely that the code in the lib (which is compiled with a normal compiler) is completely useless for your cpu ;-). Also CE is somewhat limited in it's API compared to a normal PC so not everything might work anyway.
try to compile the library in eVC4?
or look for an alternative
what kind of library do you need?
