lockman_akim
Advanced Member level 1
![Advanced Member level 1](/styles/images/ranks/glevel1.gif)
im designing the loadboard for testing new microcontroller, the impedence should be maintain 50ohm whether the PCB track or component that i used. Yes for sure i can take look at the datasheet if it state the impedence. But if the impedence is not stated in the datasheet? how can i know the impedence ? what test i should do?it is possible to know the impedence of each pin of the DUT.
