Al Farouk
Full Member level 4
I have a free core for 8051, I want to know the maximum frequency that the IP can operat with. I sent a time constraint to the desired frequency and the synthesizer (Le@n@rdo) gave negative slacks, but this -ve slack may be due to I did not set the multicycles pathes and to know that I should go through the VHDL code to understand the detailed construction of the IP (which is time consuming and violat the benifite of IP idea). does any one pass through this dilema before and what is the suggested solutions.
