how can i install a nanosim in linux ?
tuza2000
Full Member level 2
Full Member level 2
nanosim download
i have download a nanosim ,but i dont know how to install it ?
can anybody help me?
thx
installing nanosim
You must download a Synopsys tools installer.
nanosim download
copy & paste from INSTALL_README_ns.txt
This INSTALL_README.txt document contains the following sections:
* General Information
* Installation Procedure
* Post-Installation Steps
* Supported Platforms and Required Operating System Patches
General Information
This document contains quick-start installation assistance. For detailed
installation and post-installation setup assistance, see the Installation Guide
for the current release, available from one of the following sources:
* The Synopsys Installation Guide Web page at
* Documentation on the Web, at
https://solvnet.synopsys.com/cgiservlet/aban/cgi-bin/ASP/dow/dow.cgi
(A Synopsys user name and password are required.)
* Synopsys Online Documentation (SOLD), which is included with
the software (CD users) and is available for download by electronic
software transfer (EST).
* Synopsys MediaDocs Shop, at
https://mediadocs.synopsys.com
You can order a printed copy of the Installation Guide from this site.
(You can also order other Synopsys documents from this site.)
To obtain your latest Synopsys license key file, go to the SmartKeys Web page at
https://www.synopsys.com/smartkeys
For quick start licensing information, go to the Synopsys Licensing
Quickstart Guide at
https://www.synopsys.com/keys/
To obtain information on supported platform and required operating system patches,
see the "Post-Installation Steps" section of this document.
For issues not addressed in this document or in the Installation Guide,
see the SolvNet Web page at https://solvnet.synopsys.com. (You will need your
Synopsys user name and password.)
This section contains the following information:
- Installation Prerequisites
- Installing by Electronic Software Transfer (EST)
- Installing Product Files From a CD
It is recommended that you log on as root or have system administrator
privileges. Also, you must have write permission in the
installation directory.
If you did not obtain this INSTALL_README file from the EST (ftp) download
directory for your product, follow the instructions in the README or
INSTALL_README file in the download directory for the product or product
suite you are installing.
Note:
If there is no README or INSTALL_README file in the product download
directory, go to the Electronic Software Transfer Web page at
https://www.synopsys.com/cgi-bin/est.cgi
or see the EST instructions in the Installation Guide at
**broken link removed**.
1. Download the required product files to a temporary directory.
For most products, you will need to download
* A common file, which contains the install.now installation
script and other files that are not platform dependent
* A platform file, which is specific to the operating system and
hardware platform you will be using
Note:
If you download more than one product, you must copy the files for each
product to a separate temporary directory.
Example:
% cd /usr/tmp/tmpdir1
% ftp ftp.synopsys.com
220 Synopsys FTP server ready
Password: <your_synopsys_password>
230 User <your_synopsys_username> logged in.
ftp> binary
ftp> cd rev
ftp> cd ns_v2003.03
ftp> get
INSTALL_README.TXT
ns_2003.03_<platform>.tar
where <platform> is one or more of hp32, hp64,
sparcOS5, sparc64, linux.
ftgp> quit
2. Untar the common file and the product files.
Example:
% tar xvf ns_2003.03_common.tar
% tar xvf ns_2003.03_sparcOS5.tar
Note:
If the files are in tar.Z or tar.gz format, you must
uncompress them before you untar them. Use the "uncompress"
utility to uncompress tar.Z files and the "gzip" (gzip -dc)
utility to uncompress tar.gz files.
The temporary directory should now contain these files,
install.now
INSTALL_README.TXT
LABEL.SYS
README.1ST
README.ns
ns.taz files
<platform> subdirectories
where <platform> is hp32, hp64, sparcOS5, sparc64, linux, and so on.
If the temporary directory does not have the appropriate files,
make sure you have downloaded and uncompressed both the common
file and the platform files.
If the download directory does not have a common file, the software is
most likely an overlay patch for an existing release and not a stand-alone
product. Check the SolvNet Release Library for details.
3. To install the software, enter the installation command:
% ./install.now
4. Answer the installation script prompts.
When you are prompted to choose a location for installing the
software, do not select the temporary directory. You must
specify a new location.
If you are installing multiple operating system platforms, you
need to install the platform-independent package only once for
each product. The platform-independent package contains files
that are common to all the supported platforms.
5. After installation is complete, each user must set the SNPSLMD_LICENSE_FILE
environment variable to point to the Synopsys license key file by using
path syntax or port@host syntax.
Example:
setenv SNPSLMD_LICENSE_FILE /path/to/synopsys.lic [path syntax]
setenv SNPSLMD_LICENSE_FILE 27000@myserver [port@host syntax]
For more information on setting this variable and on other
steps to take after installation, see the "Post-Installation
For instructions on installing your product from a CD, see the Installation Guide.
Setting Up the User Environment
To set up your users, you must create a Synopsys source file, or modify
each user's $HOME setup files (typically .profile, .kshrc, or .bashrc),
by adding the following information to the user environment:
1. Set the SNPSLMD_LICENSE_FILE variable.
2. Add the tool executable files to the user PATH.
3. Set any tool-specific variables.
Information about each of these steps follows. For tool-specific
information, see "Setting Up <product_name> for Each User" in the
appropriate tool chapter in the Installation Guide.
This variable specifies the path to the Synopsys SCL/FLEXlm license server.
In the following example, it is assumed that the Synopsys license server is
using TCP port 27000, the default port for single servers. (However, another
port might be specified at the end of the SERVER line of your site's license
keyfile. For example, "SERVER myserver 8308a297 26585".)
Example:
* Add to .cshrc
or
* Add to .profile, .kshrc, or .bashrc
SNPSLMD_LICENSE_FILE=/path/to/synopsys.lic; export SNPSLMD_LICENSE_FILE
or
SNPSLMD_LICENSE_FILE=27000@myserver; export SNPSLMD_LICENSE_FILE
Typically, you need to add the following directory to the user path:
(synopsys_root)/<platform>/<product>/bin
Example:
Add to .cshrc:
set path=(synopsys_root)/<platform>/ns/bin $path)
Add to .profile, .kshrc, or .bashrc:
PATH=(synopsys_root)/<platform>/ns/bin:$PATH
export PATH
In many cases, tool-specific environment variables must be set.
Typically, you need to set an environment variable that points
to the root directory for the Synopsys tool.
Example:
setenv SYNOPSYS /path/to/synopsys_root
Note:
Not all tools use the $SYNOPSYS environment variable. In some
cases, other tool-specific variables must be set. See the
Installation Guide for details.
Verifying the Tool Installation
To verify that the Synopsys tools are installed correctly, see the
The Installation Guide is available in SOLD, in print format, and also
on the Web. For more information on how to access the Installation Guide,
see the "General Information" section at the top of this document.
To use Synopsys tools successfully, you must
* Be running on a supported hardware platform
* Be using a supported operating system
* Have applied the required OS patches.
For detailed information about supported platforms and operating system
patches, go to
https://www.synopsys.com/products/sw_platform.html
To obtain a matrix of supported operating systems by release,
click Supported Operating Systems.
To obtain a list of required operating system patches,
click Qualified Runtime System Configuration.
nanosim installation
the version before 2004.9 need not the installer
