In Allegro, while generating drill file, did you have the Excellon format as 2, 4 and selected options Leading zero suppression, Equal coordinate suppression and Enhanced Excellon format ?
And while importing in CAM350, you need to select
Format - Excellon,
Digits - Integer 2; Decimal 4,
Zero suppression - Leading
And the unit in which gerber was generated is to be selected.
