baileychic
Advanced Member level 3
How can I implement Phase sequence detection in PIC12F508 ?
I am using PIC12F508 and mikroC PRO PIC. I need to find out the sequence of the 3 Phase inputs. I need to check if Phases are correct (R,Y,B) or not correct (any other phase sequences). How to do that ?
Should I take any one phase as 1st phase and then find out the angle between the other two phases in the order and find out if phases are in sequence like (0, 120, 240) ?
