Re: How can I get the small-signal output resistance by spec
If you want to find derivative dVs/dIs, you can use calculator function "deriv" and calculate deriv(Vs)/deriv(Is). That means (dVs/dX)/(dIs/dX), where X is a DC sweeping variable and it will be equal dVs/dIs.
Good luck.
